Manual
- Introducing Yourself
- Set a name to introduce yourself to others.
- Optionaly If you want create or join an private session
- Put the given session key to join a private session
- Or set a session key to create a private session
- Private sessions can only be created if current session is public
- ⚠ Creating a private session, you will close current public session and expel all current users
- Click join
- Then you will be able to share your screen or watch at shared screen
- Screen sharing
- To share your screen, click on the "Share" button. You'll then be prompted to select which part of your screen you want to share
- The "Share" button turn into "Stop Share" while the screen is being shared, enabling you to halt the sharing
- Watch shared screen
- Click on "Follow" to view the currently shared screen
- To stop display a shared screen, move the mouse in the right up corner of the video to display a
and click it
SED @ Centre Inria de l'Université de Lorraine
